GS-Calc Help > Calculation Functions > Optimization/Solver Functions
LProg LProgBin LProgInt QProg minMC minSimplex root
LProg(A, s, b, c, vector, [epsilon], [BigM])
1. Purpose
Finds one or more solutions for a linear programming problem with m constraints of the form:
(1) Σj=1..n(x[j]·a[i,j]) ≤ b[i]
(2) Σj=1..n(x[j]·a[i,j]) = b[i]
(3) Σj=1..n(x[j]·a[i,j]) ≥ b[i]
and a maximized objective function:
Σj=1..n(x[j]·c[j])
2. Arguments
3. Behavior
4. Example
Initial constraints:
2·x1 + x2 + 2·x3 ≤ 20
3·x1 − x2 + x3 = 10
Objective function:
3·x1 + x2 − x3 → max
Formula:
=LProg({2, 1, 1; 1, 1, 3}, {1; 0}, {5; 10}, {4; 2; 2}, 1,,)
returns {1; 0; 3}
LProgBin(A, s, b, c, bin, vector, [epsilon], [BigM])
1. Purpose
Finds one or more solutions for a linear programming problem with constraints of the same form as LProg, where some or all variables x[i] are required to be binary (0 or 1).
2. Arguments
3. Behavior
4. Example
2.5·x1 + 1.5·x2 + x3 ≤ 15
x1 + 1.5·x2 + 3·x3 = 10
Objective function:
x1 + x2 + 2·x3 → max
Formula:
=LProgBin({2.5, 1.5, 1; 1, 1.5, 3}, {1; 0}, {15; 10}, {1; 1; 2}, {1; 0; 1}, 1,,)
returns {1; 4; 1}
LProgInt(A, s, b, c, int, vector, [epsilon], [BigM])
1. Purpose
Finds one or more solutions for a linear programming problem with constraints of the same form as LProg, where some or all variables x[i] are required to be integers.
2. Arguments
3. Behavior
4. Example
Objective function:
Formula:
=LProgInt({2.5, 1.5, 1; 1, 1.5, 3}, {1; 0}, {15; 10}, {1; 1; 2}, {1; 0; 1}, 1,,)
returns {4; 0; 2}
QProg(A, s, b, p, C, vector, [epsilon])
1. Purpose
Finds one or more solutions for a quadratic programming problem with m constraints:
pᵀ·x − xᵀ·C·x
where p is an n‑element column vector and C is a positive‑definite n×n matrix representing a quadratic form.
2. Arguments
3. Behavior
4. Example
Constraints:
x1 + 2·x2 ≤ 10
x1 + x2 ≤ 9
x1 ≥ 0, x2 ≥ 0
Objective function:
f(x1, x2) = 10·x1 + 25·x2 − 10·x1² − x2² − 4·x1·x2 → max
Data:
A = {1, 2; 1, 1}
s = {1; 1}
b = {10; 9}
p = {10; 25}
C = {10, 2; 2, 1}
Formula:
=QProg({1, 2; 1, 1}, {1; 1}, {10; 9}, {10; 25}, {10, 2; 2, 1}, 1,)
returns {0; 5}
minMC(f(x), x, v, from, to, points)
1. Purpose
Performs n‑dimensional minimization of a given function using the Monte‑Carlo method. The function generates a number of random points in n dimensions and returns the point for which f(x) is smallest. This method can be used to obtain an initial vector for minSimplex().
2. Arguments
3. Notes and Errors
4. Example (RC notation)
The r2c4 cell contains:
=exp((r3c4-1)*r3c4 + (r4c3-2)*r4c3 + (r5c3-3)*r5c3) - 10*exp(-((r3c4-3)*(r3c4-3) + (r4c4-3)*(r4c4-3) + (r5c4-3)*(r5c4-3)))
The r3c4:r5c4 range contains any numbers.
=minMC(r2c4, r3c4:r5c4, {1;1;1}, -5, 5, 10000) returns {0.675, 2.725, 2.960}
5. Example (A1 notation)
The D2 cell contains:
=exp((D3-1)*D3 + (C4-2)*C4 + (C5-3)*C5) - 10*exp(-((D3-3)*(D3-3) + (D4-3)*(D4-3) + (D5-3)*(D5-3)))
The D3:D5 range contains any numbers.
=minMC(D2, D3:D5, {1; 1; 1}, -5, 5, 10000) returns {0.554969, 2.661842, 3.279377}
minSimplex(f(x), x, v, [start], [epsilon], [max_steps], result)
1. Purpose
Performs n‑dimensional minimization of a given function using the downhill simplex method.
2. Arguments
3. Errors
The r3c4:r5c4 range contains:
{0.5; 3; 2}
=minSimplex(r2c4, r3c4:r5c4, {1;1;1},,,,1) returns {0.59358762694774; 3.00000004102304; 2.9999999389697}
=minSimplex(r2c4, r3c4:r5c4, {1;1;1},,,,2) returns 0.75509
=minSimplex(r2c4, r3c4:r5c4, {1;1;1},,,,3) returns 275
The D3:D5 range contains:
{0.5; 3; 2}
=minSimplex(D2, D3:D5, {1;1;1},,,,1) returns {0.59358762694774; 3.00000004102304; 2.9999999389697}
=minSimplex(D2, D3:D5, {1;1;1},,,,2) returns 0.75509
=minSimplex(D2, D3:D5, {1;1;1},,,,3) returns 275
root(f(x), x, x0, x1, [epsilon])
1. Purpose
Finds a root of a one‑dimensional equation f(x) = 0 using a modified secant method. The method is convergent if f(x) is continuous on [x0, x1] and f(x0)·f(x1) < 0.
2. Arguments
3. Errors
4. Example
The r2c3 cell contains:
=r3c3*r3c3 + sin(r3c3) - 5
=root(r2c3, r3c3, 0, 3, ) returns 2.02521163744482
=root(r2c3, r3c3, -3, 0, ) returns -2.38467666014657
